All Things 288XP
decableguy2000
10:27 AM
WNC
It will probably be fine. I think they come with bearings installed…again, you can probably run with the bearings it comes with, but you might consider replacing with some SKF or Nachi bearings.
Already have them. I've had this on my bench for a while, want a nice case for it. Good used ones are getting had to find.
farminkarman
I like the red & black ones
9:27 AM
Neenah Wisconsin
I built a FT 288 from a parts kit when they first came out. The cases & crank actually seemed pretty nice.
9050lx
10:27 AM
FL
Maybe I just got lucky, but my FT 288 runs very strong and has held up just fine, except for the 1st gen oil pump.
Hoser
10:27 AM
Grey county Ontario
Would a saw like a 288 be worth paying someone to rebuild? I realize this is a very general question and dependent on the condition of the saw.
But new saws aren’t free and I’ve grown fond of my ugly 288
Maintenance Chief
10:27 AM
South Carolina
That would depend upon the hourly rate, if you factor in the cost of a new 288xp which is 1200.00 generally, then consider what you'll have after the rebuild.
The 288 is a fantastic saw but if what you have is an ugly 288 that approaches the same cost as a new one ? I'd look into other alternatives.
Bama Raised
9:27 AM
Alabama
Hooray 288
Sent from the Hoskey Hill country
That's a good looking saw!
Member
9:27 AM
Once ported, is there much diff between 52 and 54mm cyls? Is one more suited to a torque or RPM build than the other? @Stump Shot
2mm's in bore diameter won't make or break you one way or the other. Just think of it as (small bore) shorter bar and (large bore) longer bar.
