- 5:54 PM
- Jun 5, 2016
- Northwoods of Wisconsin
That make you a junk collector then?I think 288's are junk![]()
Shots fired !!!I think 288's are junk![]()
Pfft. The truly questionable guys are onto pole saws and two-stroke margarita blenders nowAren't you the guy that ported a weedeater?
Pends if you fill it with concrete firstWhat size water vessel will a 288 hold in place, with small to medium swells?
…and whether it’s a LitePends if you fill it with concrete first
Somebody's been cutting pine.Found this sexy bish locally for $100...Runs good. Has a crap to of compression. Ordered a top cover, recoil and hd filter (MIA) from Duke.
I see a helicoil kit in your future....Found this sexy bish locally for $100...Runs good. Has a crap ton of compression. Ordered a top cover, recoil and hd filter (MIA) from Duke.
The mag case where the top right recoil screw goes is broken offThought about epoxy/jb weld...but I doubt it will hold. Do I need to find someone with tig/ magnesium capabilities?View attachment 408688
Soak it in degreaser and pressure wash it to see what all it needs.The mag case where the top right recoil screw goes is broken offThought about epoxy/jb weld...but I doubt it will hold. Do I need to find someone with tig/ magnesium capabilities?View attachment 408688
