mrxlh
I stayed late and finished!
- 2:31 PM
- Dec 2, 2020
- Dat Boot
Lay the D009 (Large Husky) bar on top of the D025 (large Stihl) lining up the adjuster holes, you can trace the D009 slot length on the D025 bar with a sharpie. Lengthen slot to the sharpie line, and the standard Husky DL chains with the appropriate bar adapter will work just fine. I used a drill and a file, took like 15 minutes tops. If you don’t want to modify the bar, you need to add 1 additional DL to use a large Stihl bar on a large Husky saw.Quick question, I'm mounting a 28" 3003 bar on my 288, how many drive links do I need, saw has a 8pin on it, and standard chain won't fit
