Woodslasher
Teh debil
- 7:54 AM
- Mar 18, 2021
- Commiefornia
No, there's no such thing as a 288SE. There's the 181SE, but no 288SE.That would have been a 288se?
Old girl still runs good. Here’s is running both my FT288 with 8t and ported just seeing if it seems to be stronger but of course no fair comparison because 2 different chains and 8t vs 7t on the stock saw but the ported Ft288 feels much stronger which I would hope so.
Good running pair of saws Pat.Old girl still runs good. Here’s is running both my FT288 with 8t and ported just seeing if it seems to be stronger but of course no fair comparison because 2 different chains and 8t vs 7t on the stock saw but the ported Ft288 feels much stronger which I would hope so.
Thanks Josh! Hope you get back into buildingGood running pair of saws Pat.
Well the FT is flying with 8 pin and I can lean on it pretty decent and it’s still holding rpm. Small wood of course. They feel totally different it’s at 15 blowdown on the FT 100 exhaust and probably 20 blowdown on the Husky 100 exhaust whatever stock is with a gasket. Like I said it’s not a fair comparison but I think it’s safe to say you can gain more power than a stock OEM saw with AM cylinders since I’ve done it plenty. Some people still brainwashed that the OEM is always going to run better.Man they both sound pretty good!
I've only done a timing advance on one or 2 saws, how much of difference do you feel in the cut ?
Thanks for your help with that buddyNo, there's no such thing as a 288SE. There's the 181SE, but no 288SE.
Well the FT is flying with 8 pin and I can lean on it pretty decent and it’s still holding rpm. Small wood of course. They feel totally different it’s at 15 blowdown on the FT 100 exhaust and probably 20 blowdown on the Husky 100 exhaust whatever stock is with a gasket. Like I said it’s not a fair comparison but I think it’s safe to say you can gain more power than a stock OEM saw with AM cylinders since I’ve done it plenty. Some people still brainwashed that the OEM is always going to run better.![]()
Yea I definitely prefer OEM husky as well. But for what you pay for a farmertec if you want a play saw I don’t mind it. I can get a 394 for 300 bucks but it’s all worn out to hell. I’m thinking I’d rather just get a farmertec 395 and know what I got. Maybe y’all can help me out with that decision. I’d rather have both but unfortunately I’d have to sell another saw lolI looked at a couple of oem ones ,but wasn't able to lock one down in my price range yet, (got my 394xp for 300.00).
I did order a FT 288 to mess around with though.
Thanks for the feed back , i obviously prefer oem but haven't had terrible experiences with my AF stuff really.
Go easy on the machining without a decomp. A 288 will shred the recoil if you miss time the pullNow when a port the oem saw its gonna be a different sterry because I’m doing machine work on it![]()
Yea definitely.Go easy on the machining without a decomp. A 288 will shred the recoil if you miss time the pull
Yea I definitely prefer OEM husky as well. But for what you pay for a farmertec if you want a play saw I don’t mind it. I can get a 394 for 300 bucks but it’s all worn out to hell. I’m thinking I’d rather just get a farmertec 395 and know what I got. Maybe y’all can help me out with that decision. I’d rather have both but unfortunately I’d have to sell another saw lol![]()
It’s got potential I thinkIf it is junk then obviously no but if it is just dirty and faded I would go oem fo sho.
If you have to put 150 extra in parts its still much better.
The FT runs strong Pat. Nice work!Had to do a rematch of the ported farmertec 288 and the husky 288 with just a muffler mod because the throttle lever was never opening full throttle on the farmertec. Same bar and chain and both 8t.
Not bad for not having machine work. I’m usually the first one to say you need machine work to get the intake where it needs to be without having to grind it because that’s affecting the velocity in a negative way grinding it down a lot. BUT it just so happens the FT cylinder intake landed at 77 no gasket. Lucky cylinder? Don’t know but I literally did not touch the intake port.The FT runs strong Pat. Nice work!
Hmm. Could possibly be a lucky a cylinder or they are getting more consistent.Not bad for not having machine work. I’m usually the first one to say you need machine work to get the intake where it needs to be without having to grind it because that’s affecting the velocity in a negative way grinding it down a lot. BUT it just so happens the FT cylinder intake landed at 77 no gasket. Lucky cylinder? Don’t know but I literally did not touch the intake port.![]()
I’m going to order a few more and compare them. We will find outHmm. Could possibly be a lucky a cylinder or they are getting more consistent.
