Ketchup
Epoxy member
- 10:41 AM
- Mar 12, 2018
- Colorado
Ok thank you. I have been searching to find examples of guys trimming a little skirt for more intake timing. I just don't want to grind the intake yet. I might try a 50mm pop up windowed piston from a 268 in the future with this cylinder, and they are shorter skirt. So if I ground on it now, it might be too much intake with the 268 piston.
The popup is underwhelming compared to good port work. That cylinder does look like a deal. If you do decide to grind, go through the plating with diamond. Especially the chamfer.
