661 R&D
Red97
10:43 AM
MI
What dose that wash tell you?
My semi uneducated guess.
Would be to try and angle the ex side transfers just a bit less. Not aimed at the intake as hard.
Looks to be favoring the flywheel side just a bit, but I think that is due to the cooling effect of the flywheel.
Now these ^^ statements are just my opinion and have 0 merit pertaining to the 661. Just some ideas I have come up with through reading/research, but haven't pulled enough jugs to see if it really makes any difference.
Just food for thought.
jmssaws
Banneded
9:43 AM
The awesome thing about the transfers is they feed from one spot so a water hose can give you a good idea of how they are working. They are offset and make a perfect swirl. Water don't flow like air but you can see exactly how there aimed.
The wash looks pretty good I think but I don't know a lot about what it should look like. It will carbon the pto side first because of the flywheel.
It's only got 1 tank on it so I'm surprised there's much wash at all.
Entry angle isn't changed much but opening angle is.
