661 R&D
jmssaws
Banneded
12:48 AM
im gonna say with as small a muffler outlet as im running a maxflow wont hurt it. i can pull the screen and slow it down same as my 064 and 066
its the angle im opening the transfers that makes it that way but there strong and quiet so win win
jmssaws
Banneded
12:48 AM
Ive been thinking about the "why" your seeing better results with the 4700 coil J.
Mine ran very well with the 4700 until I put a Maxflo on it which makes absolute sense. More air, more fuel needed.
Iirc some had seen the fuel issue which was thought to be a rich condition but after some study turned out to be a lean fuel curve with the 4700.
You are at 800' right? I normally cut at 2100'. Do you have a Maxflo to run with that coil or maybe try without a filter? Just thinking the Mtron cant fully compensate for all conditions.
the updated coil hurts it just a smidge i believe.
starts better with the 4700 for sure,usually one pull cold.
paragonbuilder
1:48 AM
Norwich, CT
Can you explain what you are doing with your angles on the transfers?
jacob j.
Only the weird
10:48 PM
Coastal Oregon
@Jacobj knows about this i believe ,think it was a common thing on metal flywheel saws .
I worked for a big logging company for several years- at the time their main landing saws were 038 Magnums running 32" bars with .404" chain. The 038 has a heavy enough case to last for years with .404".
jmssaws
Banneded
12:48 AM
Morning Jason, you seem lost without your phone. Keep waiting for a text
Oh yeah, that 661 sure is Niiice!
I ported a nice old flat top 066 arctic today,know whos it is?
I built it with beating the 661 in mind and the few cuts I made with it tell me its gonna be close.
I have pics of the port work that ill post when the wife gets home.
video after while.
I cut 040 off and finished up at 99 122 81,its real strong and loves rpm
Deets066
AKA Deetsey
1:48 AM
video after while.
Yup, that flattop artic would be mine. You still got my address?
