Redfin
Meh...
- 8:15 AM
- Dec 24, 2015
- Central Pa
that cylinder only has 012 from the chamber and 175lb compression and no epoxy. lots of work in the transfers though and thats where the power is.
absolutely clobbered my 066. lol
I think that a 7 tooth .375 is best in timber. That's just what I prefer. Used an 8 on and off and there was something about it I didn't like.Top to bottom. .375/7 .404/7 .375-8 .375-9View attachment 37408
it was cut this past spring and has laid in the sun since so its hard as it can be.Looks old and dry. Whats the difference in the 661 Jason? The quad make a difference over the 2 ports or the mtronic adjusting the saw to the different loads? Seems to me it should be a job to outguess mtronics as many times a sec. As it adjust? All 3 saws look dang good
ill get a pic of the 404 8pin.Top to bottom. .375/7 .404/7 .375-8 .375-9View attachment 37408
i only use a 7pin falling,the saw is much more forgiving.I think that a 7 tooth .375 is best in timber. That's just what I prefer. Used an 8 on and off and there was something about it I didn't like.
I good strong flat top. They are great. I had one for a good while, I always said if I could hold onto the saw and push it though a tree with my feet it would take it like a champ and just pull through it and work.i love a flat top 066 but if i was cutting timber again id be running a 661.
as far as this one is ported the mtronic works perfect,its always tuned and ready.
got a few videos loaded with her phone
new 404 full comp that i hit with a double bevel a couple times and a giant 8pin,i dont have anything else that will load a saw like this setup does.
its not my saw,this is the free port job so I could play with a 661. this is rodneys saw. @leadfarmerYou gonna send this saw out for us to play with Jason?
[emoji106] [emoji106]thanks for the kind words men.
its the best all around running saw ive ever built,its cool to have a saw this strong and it be so well manerd.
im sold on mtronic. this saw is some kind of stout and enjoyable to run.
I can beat it with the other cylinder,it will gain with more bd
