661 manifold problem solved
Member
12:45 PM
Actually those gals on those sleds raise thousands and thousands of dollars for local needy people each and every year. The people in charge of it see that every cent gets used for the purpose intended and not just a fraction thereof as well. And we really don't have anything else to do this time of year up here so...
12:45 PM
Cool......
At least there is a reason for it.
fordf150
1:45 PM
Newcomerstown ,Ohio
That would significantly limit AV travel.
I'll take that if it means the saw is usable past the first time it gets pinched and you pull on it. at least with the old 660 or jsut about any other saw if you yank on it the most that happens is a broken/bent/busted A/V mount but that isnt the case with 661's.
treesmith
Tree Hugger/Cutterer
3:45 AM
Straya
It's pretty nipply out now. I was out for 3 hours feeding and checking water for cattle. Under armour is good stuff. Just need to work on the boots.
I used neoprene fishing wellies, fisherman issue, steel toe. Spent many an hour in icy ditches no bother, bamboo socks are good too
