I timed them 2 or 3 times and the single fastest cut was the euro by .05 seconds. The rest of the cuts were pretty well even. 4700C sounds the best but still has too much timing.I was liking the euro one but then I queued two at a time to run simultaneously and started liking the 4700c. I wish I could have hands on experience with your saws Dave. They're so close in the videos it's gotta come down to feel.
I have a 4700 and a 4701 here I can put my light on. Id like to do the same with the euro coil.Someone needs to test them with a timing light. I don't have one or I'd try it
Not sure. It was able to flood it down and I kept leaning it out.Do you think that the smaller Venturi on the tillotson has anything to do with how it is running. The tillotson HS 320 has an 18.3mm and the walbro wj have a Venturi of 19.05 mm.
