661 coils
94BULLITT
10:01 PM
VA
Does the Euro saw use a different flywheel?
Sent from my SPH-L710 using Tapatalk
Chainsaw Jim
Con Artist LLC
7:01 PM
Springfield Oregon
I was liking the euro one but then I queued two at a time to run simultaneously and started liking the 4700c. I wish I could have hands on experience with your saws Dave. They're so close in the videos it's gotta come down to feel.
10:01 PM
I timed them 2 or 3 times and the single fastest cut was the euro by .05 seconds. The rest of the cuts were pretty well even. 4700C sounds the best but still has too much timing.
jmssaws
Banneded
9:01 PM
With a carb and unlimited coil how fast has anybody had one?
I've never heard one that sounded unlimited.
jmester
10:01 PM
VIRGINIA
Do you think that the smaller Venturi on the tillotson has anything to do with how it is running. The tillotson HS 320 has an 18.3mm and the walbro wj have a Venturi of 19.05 mm.
jmester
10:01 PM
VIRGINIA
When you where using the euro coil was it the stock key or advanced. I would think you could push some more fuel to help use up some of the timing.
10:01 PM
Advanced so far it was making my tach go crazy once it was good and warm. I set it at 13.3k and then it was 12.9k and went like a limited coil.
