572xp carburetor nozzle
buckin-wood
2:33 AM
North East
The saw was running insanely rich and dying when coming off throttle. I threw a rebuild kit at it but still not holding vacuum and sounds like the nozzle is leaking. I can't seem to find a part number for the nozzle anywhere, but did find a part number for the 562. Anyone know if they happen to be the same nozzle? I know the 562 and 572 carb body similar as they use the same diaphragm kit.
buckin-wood
2:33 AM
North East
found a part number on Zama's website...
I don't see it available for purchase anywhere. I reached out to Zama to see if they could get in touch with a retailer that could special order it. No word back yet.
Poleman
12:33 AM
Rapid City,S.D.
I’m thinking it’s the same Nozzle by the build specs.
When you pressurized the carb put it in water/fuel to see if you can see where it’s leaking at. You’ll know as you’ll be able to see bubbles coming out of the Venturi from it or any other spot on the carb.
Possibly not the carb at all…. I had one that drove me nuts and it turned out to be a leaking transfer cover… after investing in another carb. Sealed leak and all was fine with the original carb. The 5 series saws dump fuel like crazy when they have an air leak as it’s trying to compensate for it… it a good thing as it saves burning up a saw… but can be hard to diagnose. I just knew mine was the carb which it wasn’t.
buckin-wood
2:33 AM
North East
When I first started diagnosing the super rich condition I assumed I was going to find a leak, probably crank seal, and auto tune trying to compensate. However the saw holds pressure/vac just dandy. The carb holds pressure on the feed side, but will not hold any vacuum on the purge side.
looks like the nozzle part number for the 562 el44/46/48 is different than the 572 carb. suppose it would make sense the larger saw might need to flow more fuel. so far I've struck out with everyone I've contacted trying to get my hands on the nozzle. The fact Zama lists the nozzle part number and indicates inventory makes me think I just need to find the right person to special order it. The hunt continues.
buckin-wood
2:33 AM
North East
I had a spare 562 carb on the shelf. Punched the nozzle out of the 572 and 562. Both are 5x7mm. Atomizer looks the same, but the feed hole is larger on the 572 nozzle.
562 on left 572 on right
this is a dumb idea right?
chances I can get all the brass out and don't clog the atomizer? I held the nozzle upside down while reaming the hole out. I'm hoping most of the debris fell out. Tried flushing a bit with kroil then a few minutes in the sonic cleaner with the feed hole facing down. I figure it's worth a shot.
Assembled the carb and tested. Holds vac on the purge side no problem now. I'm hopeful this was the root of the problem
