461/462/500i
pwheel
Finis Origine Pendet
11:30 AM
MA
You are going out for the day and have your choice of all three.
Cutting hardwood in the Northeast, red oak, white oak, black cherry, some may get a little over 2 ft. at the butt.
Which saw do you take?
If I'm in the woods for the day, the idea of fun goes away after the first couple of hours. After that, it's a matter of efficiency and I'd choose an ms462 w/20" bar, semi-chisel chain for the wood you mention.
timberjack90
10:30 AM
wisconsin
I've been running 2 462's for my main cutting saws for the last 2 years, and in January bought the last 461 in my area that I could find. I much prefer the 461 for a 25 inch bar ( but I prefer aggressive rakers and 8 pin rim) . fuel consumption is about the same or less at the end of the day.
toolmaker
11:30 AM
Tyrone, Pa
Why do you prefer the 461?
pwheel
11:30 AM
MA
Stock 461: Lower bore/stroke ratio + larger displacement = more torque w/ longer bars & aggressive raker heights.
Stock 462: Higher bore/stroke ratio & lower piston speeds = a lightweight speed saw with a higher rpm power band and standard raker heights with longer bars.
Ported is another story...
timberjack90
10:30 AM
wisconsin
It seems the 461's have a much smoother and predictable power band. They seem to last forever my old one is getting towards 10 years old it's cut a lot of trees and bucked more. After about 8 months I noticed a performance drop on both 462's but I'm thinking its plug related.
pwheel
11:30 AM
MA
It seems the 461's have a much smoother and predictable power band. ....
This. ^^^ Same with my 461. I'd probably be just as happy with a 462, though. Or a Husky 572. :)
11:30 AM
My ported 460 and hybrid have more torque, but the 462 is lighter and very fast, so it depends on what I'm cutting. Also, smoother and the filter stays clean!
11:30 AM
The 462 has torque… but it’s just a narrower useable range compared to the 461 or even a 572. In timed cuts the 462 is as fast or faster. Just not as “forgiving” as the other two. I bet that could be helped with a portjob that lowers the exhaust and adds a little compression.
