440/460 Hybrid question
Canadian farm boy
“Normal” people scare me.
12:51 AM
Ontario, Canada
100/116/78 and it would 4 stroke to 16k easy.
The numbers I used in my current hybrid were recommended buy another builder.(102/118/78). My saw IMO works great. Has good speed, throttle response make decent torque to pull a 25" bar. I really like it. Great work saw. I like it a lot.
Now what I'm wondering is what would I expect to see using the numbers you mentioned? My next hybrid I'd like to see as more of a gtg saw. I'm planning on using it with an 18"-20" bar.
What's your thoughts?
mdavlee
Hillbilly grinder
12:51 AM
TN
This one did fine with a 25". For playing in 10x10 I might go 95-96 110 and 75 with epoxy. I run higher exhaust than a lot of guys. It's my preference and makes a little lower compression.
Canadian farm boy
12:51 AM
Ontario, Canada
The 046 jug I've got coming has already been ported. I don't know what the numbers are yet but I will definitely check them before I do anything. I don't want to mess up a good thing.
I think I'm gonna order a couple extra Pistons to "chop" up and see what I like.
12:51 AM
I generally like to go OEM, but the Meteor piston I saw for the 460 had wider skirts, which will give you more latitude when porting.
Basher
1:51 AM
Canada
Do you have such a hybrid? Did you port it yourself? Any vids of it?
Thanks.
I do all my own porting, I have 4 hybrids, built the first one in 07 and improved upon them somewhat by 2010, they have almost replaced my beloved 044`s. Randy can tell you where the numbers I posted came from.
12:51 AM
You only posted one timing #, but it is the same # as on one of my favorite saws!
mdavlee
Hillbilly grinder
12:51 AM
TN
I've set 460s at 97-98 and 114. They still pull a long bar just fine to me. Full comp on a 110dl bar is a load for a 76cc saw.
12:51 AM
I run RSLH on my 36" bar. I'm sure it could pull full comp, but this seems to work well and should clear the chips better.
Miller Mod Saws
Chainsaw Masseuse
11:51 PM
Ravenwood,MO
Have you tried a low intake on these? I generally don't run this low of intake but I like 100/116-117/82. Something about these saws seem to like a low intake. Guessing it's the small case capacity feeding the top end. :)
mdavlee
Hillbilly grinder
12:51 AM
TN
81 is as far as I went. You start loosing some push for the charge with less than 30° of case compression.
Canadian farm boy
12:51 AM
Ontario, Canada
@juttree when you are porting the intake on the 046 jug there is a small "bump" inside the intake runner. Be careful when grinding on that spot. The material is very thin and you can easily make a hole.
I found out the hard way. I fixed my screw up with a bit of JB weld.image.jpegimage.jpeg
