400.1 first impression
Duane(Pa)
It's the chain...
3:31 PM
Centre County
What blows is that they’re not here in the USA to be “bought’n”
3:31 PM
Have you ever seen the exhaust outlet on a Stihl 260? It’s about the diameter of a pencil… I think restrictions are their go-to for reducing noise and emissions.
They’ve clearly been doing some work with acoustics.
Most of the newer Stihls have baffles the twist the exhaust after it exits the cylinder. When there wasn’t enough room to accomplish their goal, they started the twist in the exhaust port (462).
The noise canceling effects of colliding acoustic waves are being taken advantage of. Most of the newer mufflers place the outlet as far back in the can as possible. They are also flowing more and making less decibels.
jurchybald
9:31 PM
Slovenia
Been living with 400.1 for months now. All I can say is I hate it. It runs so fuggin lean I don't know when it's running out of fuel. Stock or ported. So this week I drilled every hole on carb I ever heard people drill. Tomorrow I'm buying new carb. Can't wait for 564xp.
lehman live edge slab
Live Action
2:31 PM
Mn
Can’t be that lean because if it was it wouldn’t have made it through the tank.
bwalker
3:31 PM
Montana
How are you determining its lean? If it was indeed lean torque, would be diminished. How does it perform?
DND 9000
9:31 PM
Germany
They aren`t set up to lean. If this would be the case they would blow up en masse. Without proper testing equipment you can`t know if it is lean or not. (exhaust gas probe, for lambda testing). Yes these engines can run lean due to air leaks, clogged filters or misadjusted inlet control levers. But that would not be the fault of m-tronic, these are maintenance or mechanical failures.
And drilling and destroying a fairly new carburetor is in my opinion just stupid, just for the guess that the engine is running to lean. If you are really worried about it, give the saw to your dealer for a complete check. If there is really something wrong, the dealer will take care of it.
bwalker
3:31 PM
Montana
I’ve never heard an mtron four stroke. They go right to the limiter…
Lest we forget this is about emissions.
Let's not forget 4 stroking is so rich the engine is misfiring. Its an easy way for guys to tune to, but not great way performance wise.
The Mtronic and Autotune saws I have ran always feel bang on and exactly like a tuned my carbed saws.
EFSM
2:31 PM
Extreme southern IL
Sounds like a pop of pressure may be too high, a little bit like the Husqvarna 550s and 562. Some of them are over 30 psi from stock.
