HELP! 395 milling saw
DillonBuck
10:30 PM
Pa
I have a customer who wants a milling saw.
I’m getting a 395 clone, and doing QC.
He doesn’t want any porting but I suggested a muffler mod. Having never milled, I’m wondering how that should be done? I don’t want it burning his wood, or on his face. Maybe a deflector faced toward what’s normally the bottom. Of the saw? Would that make the mill hot?
Junk Meister
9:30 PM
Nebraska
I would think spacing the power head farther back and a Minimally restrictive deflector "SHOULD" be safe but COMMON SENSE is paramount. (BIG WORD in small case letters))
Only drawback is size of the cut.
DillonBuck
10:30 PM
Pa
I’m not thinking some absurd pipe, just a 1” pipe sticking out an inch or so, or a deflector.
Prefer the pipe for better sound(not so damn loud) and my pipes look better than my deflectors.
Junk Meister
9:30 PM
Nebraska
Your Project. I was addressing the heat VS wood.
ammoaddict
10:30 PM
Granite Falls, NC
If you Google 395xp muffler mods, I'm sure you will get some ideas. Lots of people put a red97 deflector in front of the existing outlet. Yes it's on the bar side but when you mount the mill on the bar the deflector will be a safe distance from the wood.
Ketchup
Epoxy member
8:30 PM
Colorado
For milling I put a 1”ID pipe out the starter side of the can tilted away from the operator. It’s loud, but it’s the least exhaust you have to breathe and it moves a lot of heat. I’ve always thought about extending the pipe with flex hose to the top of the jig.
395 isn’t a terrible mill saw, but you can overheat the clutch. Don’t force the cut and keep your chain speed up. Auxiliary oiler helps a lot for 36”+.
