- 1:37 PM
- Dec 31, 2015
- East Jordan, MI
My 394 has a walbro wj39 on it. Before the MI gtg, I picked up a k10 wj kit for it but the Welch plug and screen weren't the right size. But I mainly got it to replace the diaphragms anyway. So I used everything else in the kit and cleaned out the screen.
After sitting for a month, today I got it ready to cut wood this weekend. It was lean on the low side, so I gave it 1/4 turn, and then another, and another. Still lean. Took it apart again and cleaned everything by eye, spraying brake cleaner into the holes and watching it come out the bore passages. I bent the needle lever up maybe .010 or .020 to attempt to allow more fuel in.
After reassembly, I gained a slight bit of L adjustment, but I'm too rich on the H needle. If I turn the H in tight, it'll still run, 4 stroking heavily. This is how it ran when I originally put it together, and why I installed the kit.
I'm not a carb guru at all, just what I pick up on here. Any help is appreciated
