SOLD 385/90 bits 066 piston
cabbageroll
7:56 AM
B.C
31E7C5B2-75F2-4361-BD7F-B5C08261815C.jpeg B9B557C0-5A1D-454C-AA1A-F36113AEE3BD.jpeg A3C71F58-0DAF-4E8C-9D80-0E06238101CE.jpeg 94714C93-547D-4154-B0FB-52DCF44E053E.jpeg Case halves
3pto reds in best shape I orange has good top screw but a dawg bolt snapped in there..
1flywheel side- top screws need repair
2x385 cylinders might clean up
2x385 pistons could probably use ‘em.
2x 385 caber rings
1 carb base plate
1 red carb base plate - if your into that…
1 black coil.
1 potentially suspect blue coil
2xbrake spring covers
1 brake spring
2brake bands
1 muffler bracket
1 air injection shroud
2 little dawgs inny and outty
2 big dawgs “ “
Used oil pump
Throttle cable holder.
Oil pickup tube
Oem gasket set
Bar plate
Couple screws” loose “
1 crank bearings a bit dirty could probably clean it up if that’s your thang
Have a few more practice cylinders in 390 form I’m sure and some other random additions.
$180 USD?
Hard judge used saw bits
I’m sure we can figure it out
+shipping from Canada
meteor 066 piston in box
Offers?
