- 11:28 AM
- Jan 8, 2016
- Farmington, CT
Ok, just rebuilt a 372, base gasket delete, 1184 sealer, muff mod, nuthin crazy.
I did the pressure test twice, which included the intake boot.
I have tried 2 carbs, same issue...
The saw has an erratic idle. On a previous saw I fixed this with a new carb. On this saw, the issue is identical for 2 carbs. The high end tunes fine, 4 stroke at high, clean up in cut. The idle has a mind of its own. Turn it on its nose, the idle goes low, turn the saw on the flywheel side and it shuts off. it seems like it'll idle oddly all day if I let it, but I don't like the idea of it idling funny.
