slambox28
Rod stretcher
- 4:38 PM
- Sep 29, 2024
- Saint george, KS 66535
the new gasket is non-OE, not sure what brand it is.add the OE base gasket you removed and it will be fine. and, that BASE gasket, not case gasket... ie, the one between the case deck and the cylinder.
Would you like to sell that?Oh here is the original cylinder
The difference before and after: the "catch" doubled or more, the cyl release does nothing anymore to effect the difficulty to pull in comparison. The saw seemed to mechanically lock up on me during use abruptly (just a description of it's behavior) but it still could turn over afterwards. It didn't actually "lock up" as in weld the piston to cyl. But the after effects is enough to drop your stomach. This catch is nowhere near the same as before. THe only reason to think its hitting the cyl is from the ring impression found on the piston. And from a YT video mentioning the possibilities of certain cranks stretching.Let's try this again. When the "sticking" was occurring was the coil and/or flywheel on the saw? I'd bet $20 the piston was not touching the cylinder. The flywheel magnets pass the coil around top dead center, giving the impression that the piston is touching the cylinder when it actually is not. The poor running is probably caused by old, dirty fuel. Maybe an air leak or carb issue, maybe not. Also, fyi "locked up" means physically unable to pull over, not "not running"
Use thin solder and do a squish measurement.The difference before and after: the "catch" doubled or more, the cyl release does nothing anymore to effect the difficulty to pull in comparison. The saw seemed to mechanically lock up on me during use abruptly (just a description of it's behavior) but it still could turn over afterwards. It didn't actually "lock up" as in weld the piston to cyl. But the after effects is enough to drop your stomach. This catch is nowhere near the same as before. THe only reason to think its hitting the cyl is from the ring impression found on the piston.
It seems to me like it's in good enough condition to run it! Cyl to piston fitment is the same as brand new! I'd consider selling it but also would like to use it when in like new shape. Just need to figure out the actual problem; why it seems to have a mechanical issue. And btw the new farmertec kit has a visible crack in the piston and squish band area.Would you like to sell that?
I'll buy it if the plating is good.
Does the oem cylinder have clearance issues with the farmertec piston?It seems to me like it's in good enough condition to run it! Cyl to piston fitment is the same as brand new! I'd consider selling it but also would like to use it when in like new shape. Just need to figure out the actual problem; why it seems to have a mechanical issue. And btw the new farmertec kit has a visible crack in the piston and squish band area.
Oh, that's how it's done?Use thin solder and do a squish measurement.
The farmertec piston wont fit it, here I've got a way to demonstrate squish right away: Next postsDoes the oem cylinder have clearance issues with the farmertec piston?
