slambox28
Rod stretcher
- 9:05 AM
- Sep 29, 2024
- Saint george, KS 66535
Hi, name is Brad, I have a 372 XP with the 52mm bore. Excellent saw, my favorite so far aside from: the choke lever catch not working, gotta use a homeade clip or use a stick. And occasionally the on/off switch won't kill it either, gotta use the choke. Otherwise, it is a beast and 10/10 favorite saw, got it from ebay used with a new rebuild/ big bore kit.
The issues: it seems like it locked up on me but it's not the cylinder or piston. Old fuel was used from an oil bottle that was 3 months old and expanded to split the bottle. So, the fuel was exposed to open air for months, but it certainly had oil.. the saw sat in a horse barn for several months with an open wall. It's crazy how much dust, sand and debris finds its way into crevices in a short timeframe.
I went to run the saw, it's dry so fuel is added. After adding fuel, then making sure the bar oil was full too or adequate level. Just one quick thing to cut, got it running and it ran enough to get hot even with this old, oxydized fuel from a split oil bottle. Got it warm to cut this piece of wood and out of nowhere it acts like it locked up; bogs down, shuts off and wont fire back up.. instantly I think the fuel was somehow no good even though it did for sure have oil mix.
The saw has a catch at one point of the rotation. Just one point not a resistance the whole rotation. It has this catch even with the bar taken off. Later on I install a new cylinder and piston kit and the exact same issue.. the one thing I haven't tried yet is to note at what point in assembly does this create the catch. The catch is not seeming to be the bottom and top end engine assembly as I've tested. The catch is not the pull handle when taken off. This happened just after getting hot enough to stay running when cutting through one board. The fuel was old and oxydized but had oil for sure.
Any ideas what could cause this on the 372xp? Gotta clean all the parts now to assemble again and get new piston rings for the original top end.. The farmertec top end kit has thicker piston rings than the one originally on it.
If findig out anything will keep posted
