372 xtorq porting
Levi3294
Active OPE Member
12:25 AM
Tennessee
D3B42189-EBBF-4C82-B70B-824CBBA88B4A.jpeg I picked up a new to me 372 seems to run good to me I would like to find someone to get me alittle more out of it will spend it’s life with 20in bar maybe a 24 occasionally located in Tennessee not that that matters much
Sawponder
12:25 AM
Virginia/N.Carolina
I've got a brand new oem cylinder kit that's been ported for 350. Could use it and compare power between the 2. Or turn around and sell your used one on here. Or you could send me yours cylinder and I can port it for 150 or the entire powerhead I'll port it for 250
Sawponder
12:25 AM
Virginia/N.Carolina
Pictures of previous builds available. I handtool my ports with precision machinist files, no electric tools used unless I need to remove a bunch of material
mrxlh
I stayed late and finished!
11:25 PM
Dat Boot
I’ll 4th Kevin @huskihl for sure, Kevin has ported a 543xp, 346xp, 7900EA for me and I own a 357xpg he ported for another member, all stellar performing saws.
farminkarman
I like the red & black ones
11:25 PM
Neenah Wisconsin
It would be great if you posted a build thread. I personally am struggling to envision porting a cylinder with files for a few reasons.
Sawponder
12:25 AM
Virginia/N.Carolina
Well, i had to break out of the mold somehow.
I guess i could show a bit of the process. And the tools necessary. It does take quite a bit longer than using a foredom/dremel.
Picture of a 572xp im doing right now for my buddy Dom from NY. He sent the entire saw in and wants a very warm saw to compare to his other stock 572xp he has at home.
Starting early today to try and finish up several cylinders for the local guys.
I don't charge nearly as much as the other guys do mainly because usually guys send me their cylinders and pistons (easier on them they say) but if someone wants to send the entire powerhead and have me map their ports for a bit of tweaking, i can do that too.
Pricing depends on conplexity of the cylinders, and the saws that really benefit are multi-transfer port saws like 7900, 441, 461, all the autotunes do extremely well also.
Send a cylinder and piston in starting at $150
Woodpecker
Sassy Madam
12:25 AM
Folks as it stands member @Sawponder hasn’t been seen on here in awhile. A couple members sent funds to pay for parts and haven’t heard anything back from this member in weeks. I will be going through his listings and changing them to NLA. I would recommend not sending funds or doing business with him until he decides to explain himself.
Nutball
11:25 PM
Mt. Juliet, TN
I don't see any right angle files. How do you port the upper transfers?
Woodpecker
Sassy Madam
12:25 AM
To follow this up. It would appear that @Sawponder has made things right with all the members here he owed parts too. Not sure if they will post again so the right angle files will likely remain a myth-tery.
srcarr52
12:25 AM
Iowa City
It was a 572 cylinder shown... it has transfer caps.
Sawponder
12:25 AM
Virginia/N.Carolina
A 572xp jug was shown bc that was what I was doing exactly at that time. Just figured I'd show it since it was on the bench and I was actively working on it.
Sawponder
12:25 AM
Virginia/N.Carolina
