- 3:06 PM
- Dec 29, 2015
- Strong Island NY
Any pics of the innerds?
I'm digging the use of a tensioner in the top cooling fins to hold down the top cover.
The AV spring mount pretty clever as well.
Thanks Adam. I am in Cambridge, owner of Camco industriesSorry I missed the original tag.
Where do you stay Phil?
And very well respected ute decks they are too mate.Thanks Adam. I am in Cambridge, owner of Camco industries
They fit straight on, the crank is the correct length, the MS361 flywheel has a different taper hence the need for the 360 flywheel, The coil needs spacing out slightly to align with the flywheel magnets.@stumpyfine , are there crank modifications necessary to fit the clutch and flywheel?
Thanks,sure will.have just started working on a MS461 stroker, will do thread on that one.Looks like a fine build you have there @stumpyfine . If you ever have it back apart it would be great if you did a build thread.
Hello Phil, good to see you here. I'll have to give it a run when I'm next upThey fit straight on, the crank is the correct length, the MS361 flywheel has a different taper hence the need for the 360 flywheel, The coil needs spacing out slightly to align with the flywheel magnets.
Yep all good MarkHello Phil, good to see you here. I'll have to give it a run when I'm next up![]()
I like it! Thanks for sharing.They fit straight on, the crank is the correct length, the MS361 flywheel has a different taper hence the need for the 360 flywheel, The coil needs spacing out slightly to align with the flywheel magnets.
