357 carb on 346xp
longleaf
12:02 PM
Dot, GA
I was wondering if anybody had any good pics of how to properly install the 357 carb and intake on a 346. Also is there a screw type clamp that will fit the 346boot?
ranchdadmike
12:02 PM
AL
ranchdadmike
12:02 PM
AL
Mine has the full 357 intake tract..boot, filter, etc. Some have had (small) clearance issues with the linkage in the carb box floor I hear. @rattler did mine awhile back and as far as I know and see it’s a straight bolt on. I think some have used the 346 boot and filter with no issues but I think the larger bore 357 is preferable
longleaf
12:02 PM
Dot, GA
I guess since I need a new boot I should just get a 357 boot too. Does it have the same clamp as the 346 or will the 390 clamp work on the 357 boot too.
72thing
Chain dulling master
12:02 PM
Georgia
@longleaf , here's the bubble show from the factory metal clamp. It wouldn't hold any pressure at all.
Found an Oetiker clamp used for a CV boot that fit perfect. No more leak. I'd prefer a screw clamp, but this worked good and it has way more tension than the OEM clamp.
longleaf
12:02 PM
Dot, GA
Thanks for Press and vac testing it. That would definitely explain the leaning out lol.
