346xp teardown vid is up. ....bolt for bolt rebuild
Mattyo
Youtube speciawist
1:46 PM
Farmington, CT
Part 3 is saving right now, will be uploaded this evening.... have to wait for part 4 and 5 for a bit ....
Mattyo
Youtube speciawist
1:46 PM
Farmington, CT
parts 4 and 5 are shot, the saw does pop w/ brake cleaner down the air horn :) its alive
will get a bar and chain on it eventually, then send it along to its new owner!
1:46 PM
Nice job Matt. I noticed that you did a mild port job, but didn't do anything with timing. Is this basically a stock saw?
Mattyo
Youtube speciawist
1:46 PM
Farmington, CT
mild port job? what do you consider a wild port job? :)
I didn't advance the flywheel ... but the cylinder is fully worked over ...muff modded too.
1:46 PM
I said MILD, not wild. Lol. Looks like you just smoothed things out a little around the ports.
Mattyo
Youtube speciawist
1:46 PM
Farmington, CT
no... not just smoothed. ...I ground everything. timing was adjusted significantly, ports widened, transfers opened at the bottom ... etc. was quite a bit of grinding.
the upper transfers I do in the dental office w/ diamonds. not the most ideal tool for it, but it does work
Mattyo
Youtube speciawist
1:46 PM
Farmington, CT
Editing vids is crazy. ....takes a long long time. I don't even watch the vids myself so I have no idea how they come out lol.
Btw. ...figured something out on the mill. Gotta take the bark off...the run the hose at high pressure at the blade while cutting though the outside of the log. ....my blades are staying sharper longer.
Sup dan?
Tor R
Novice, Leg model #2
7:46 PM
Mandal
Nice thread Matt.
I do crankcase&crank a bit different on those saws who has seal in PTO bearing.
I mount PTO bearing on crank first and place it in the freezer, heating up the case half to about 130° celsius, it slide straight down with those temperature diffences.
Dumping the whole thing a few minute in freezer again to help cooling fast down again.
Doing gasket and all those things on PTO side.
Flywheel side is 200° celsius, it's the temperature I feel I can reach to mount bearing and have enough heat transfered to the bearing for sliding everything together without torquing it together with screws.
This is what have worked best out for me, it doesnt need to be the best way for others
Mattyo
Youtube speciawist
1:46 PM
Farmington, CT
Yep...lots of ways to do it. Best to have the proper tools though no question.
