3-series huskies
Armedandhammered
Active OPE Member
1:37 PM
SWMO
Wow, the responses here are outstanding! Many thanks for not shredding the new guy and giving me plenty to think about. I look forward to reporting back on what direction I go and how pleased I am with my new life choices vs grabbing an occasional use “one size fits none” saw.
Member
1:37 PM
Take plenty of time and do your research, ask plenty of questions as they arise, the only dumb questions are the ones that go un-asked.
There's plenty of folks around here that can help you succeed with your journey into acquiring that coveted ported saw, with answers from experience.
bryanr2
2:37 PM
USA
I love a OE 372 and the 346/353. Honestly I love every 2 and 3 series saws I’ve owned. 242xp, 246xp, 2 254xps (one with heat), 257, 9 262xps, 2 272xp, 2 288xps (one nos), 2100, 2153 (346 in red), 357xp, 2 359s, 2171 OE (red 372), 2171xpw, 372xp, 2188 (red 390xp) 2 395xp, and 1 3120xp. I think that’s all of them. All ported by mastermind. I’ve had 3 5 series saws as well.
My current lineup is stihl ms400 Mastermind, 288xp, and 395xp. (Although I havent received the 400 yet- I think that one will be a great do all saw.
ZERO
Simple Life
8:37 PM
Woods & Mountains
5 series early saws had some issues, mainly the Autotune Gen1 starts and hot restarts. That is no longer an issue, as technology moved on, and we here through extensive knowledge sharing figured how to start the early 2012 MK1 saws. It all depends on your choice and if you have a good dealer close by for support.
I myself cannot find a big of a difference between the 3 and 5 series in the same cc class. All ported by very reputable builders. Yes we can dyno them and pick at the numbers but in day to day use all good saws.
Lastly, don't forget to check the ads, sometimes something will pop up at quite a discount that may suit your needs.
chipper1
2:37 PM
Grand Rapids Mi
chipper1
2:37 PM
Grand Rapids Mi
OP, you'll enjoy running either the 372oe or the xtorq version, they're both great saws. I will say, the xtorq in stock or slightly modded for will have a bit more torque with a wider power band and is better on fuel. The oe can be fitted with an unlimited coil which makes them a bit easier for a new guy to tune and to hear if there's a problem; I don't recommend using an unlimited coil on the xtorq.
Another option is the red version of these, the 2171/2172 jreds, many times they go for a bit less, but chassis/cylinder wise they are identical, the big differences are the recoil angle and the top handlebars are straight on a jred vs the angled on a husky.
Look forward to seeing what you decide on and how you like it compared to the rancher. BTW, a 455/460 weighs about the same as a 372.
Woodwater
8:37 PM
Carinthia / Austria
550xpg 2015 model ported, very good saw, Throttle response is more than quick, quicker than any other saw i have, best limbing Saw i ever owned. I do not like the Mark2 of them. I also have 346 ported, has more grunt. Mostly i grab the 346's to cut wood.
but all two very good Saw's!
chipper1
2:37 PM
Grand Rapids Mi
Always late to the party! Don't bet your lunch money that I'll run a late model!
Says the guy still running a 346 😆. Hard to teach an old dog new tricks. Nothing wrong with a 346, just needs a 455 clutch cover and they make a great saw for firewooding. But, the late model 550mk1 handles better gets better fuel economy, and has plenty of power even in stock form as a limbing saw when running 18x325.
PA Dan
FYD
2:37 PM
White Oak PA
But it's a 5 series...🤮
HumBurner
11:37 AM
Humboldt
I currently have two of each, but I'd consider that if it was a late model mk1. The 346 I'd be willing to let go of isn't my prettiest saw, but she does run well.
346s and 357s weren't meant to be pretty. They get the bulk of the work done while the big saws wait their turn.
