- 12:09 PM
- Dec 26, 2015
- The land of pleasant living
I started out my MM 262 at 14,200. I'm now running it at 13,900. It seems to be happier there.
The 242 has the same difference between transfers. Why would they go with the indent when they could have changed the contour of the flywheel. I love the reverse engineering of saws.Take a looks at the tunnels in the decomp vs. non decomp jug Dan.
Also, if the uppers are equal on both sides with a ring.
Most of the 262's I've seen do NOT have equal upper timing. Very odd. I wonder why they did that and I doubt it's a mistake. IIRC, the flywheel side has the indent on it and I believe that they set that transfer higher because it flowed slightly less.
Jug design is simply excellent for performance. The lowers are right up against the piston skirts. Huge tunnels compared to an 036 Stihl.
The intake tract sucks balls though. Even with the 87 carb, it ain't enough to feed this beast. We need to find another way. @Chainsaw Jim, any ideas on this?
At least for me, the 262 doesn't want to Rev. the fastest I've done so far was happy at 13,800 to be safe. A comparable Stihl 036 will piss rev 4 stroking 1000 rpm higher. I blame the intake tract fo this, I believe it's the limiting step.
Mine seems similar. I'd like to try 14200 and 13800 on the dyno and then stare at the graphs.I started out my MM 262 at 14,200. I'm now running it at 13,900. It seems to be happier there.
I tune fat a lot. I can find rpm in the cut with rakers and dog pressure. I come from the airplane world and power settings are largely based on fuel flow. My bottom ends are juicy and that keeps them from blowing up, so I can run the snot out of them. I get real chicken about a saw tuned lean. Too close to the edge for me. Did I mention airplanes?I think everyone is always trying to get more unloaded Rpm, but it's really irrelevant unless it can maintain good rpm under load.
I'm beginning to find that tuned a little fat actually performs better working. And its better for the saw.
I've never played with lean tunes more lately....and I've come to the same conclusion that I did several years ago. It takes fuel to make power.
I think the staggered trans opening has more to do with exciting a swirl scavenge than flow restiction. If you've ever noticed a 372/390 exhaust, its skewed to one side, and transfers are also staggered. It works pretty good to port with that in mind sometimes.The 242 has the same difference between transfers. Why would they go with the indent when they could have changed the contour of the flywheel. I love the reverse engineering of saws.
I stagger the uppers all the time.Take a looks at the tunnels in the decomp vs. non decomp jug Dan.
The farther away from optimum rpm the easier it is to bog back to optimum rpmI think everyone is always trying to get more unloaded Rpm, but it's really irrelevant unless it can maintain good rpm under load.
If you want to see some skewed ports put a 056 mag 11 cylinder on a 1122.I think the staggered trans opening has more to do with exciting a swirl scavenge than flow restiction. If you've ever noticed a 372/390 exhaust, its skewed to one side, and transfers are also staggered. It works pretty good to port with that in mind sometimes.
Yep got 8 of them in my barn, pm coming
Yes the short stroke of the 340 is tough to beat. And the 2.02 valves in the x head is what makes the power for sure. I going with a 360 in my 68 cuda, maybe a stroker kit making it a 408. Glad there are some Mopar guys on here.
