2100 CD Build
hacskaroly
2100 Fanclub Member
11:15 PM
Northern Idaho, Ehh
What I did not know about that saw was the fact it had rear bracket from the air box to the carb .Without it the carb could rattle around lossen the crab bolts then it would suck air .
Yeah, its crazy how that carb will just rattle around without the brace. Crazy simple fix! Luckily mine still had one attached, but I scoured the IPLs because I was still missing many pieces. I didn't realize that some of the pieces changed a little over the years and ended up getting some stuff that didn't fit and had to modify it.
Sloughfoot
11:15 PM
Norcal
I haven't a clue if I got all the necessary chingaderas between the clutch and oil pump or not.
Sloughfoot
11:15 PM
Norcal
I think #15 is the oil seal. My #9 ended up being in two pieces (nylon I think), but I used it anyways...lol
I believe there was one called a dust seal or something that I didn't have room for, another one in there that's pretty mangled.
Seems to work.
2:15 AM
If you look back at the carb picture I sent in it shows the right angle adapter used with a vee stack. All that weight is on two rather long bolts which naturally would oscilate more without the brace bracket in place . All I know is that thing had sat on a barn floor on some island off the Washington coast for twenty years with a bad coil . I got it cheap from another forum .That thing in good tune will really scoot but if it's been modified I have no idea ,never looked to see .Even if I did my knowledge of Husqvarna porting is not real good .If it were Stihl or McCulloch that would be another story .
265RX
Active OPE Member
8:15 AM
Italy
Good morning everyone, is it possible to install a 394 carb in a L2100?i can t find the original one. Would it get some power gain?what about trying with the 3120 xp carb?
srcarr52
2:15 AM
Iowa City
So would be with the 394 carb or this one performs better than the 395 one?are they hard to install?
You wont see much of a gain, it's more for the modern features like fast idle with the choke lever and better idle from the nozzle style carb.
You have to create a longer throttle and choke linkage, and it moves the air filter back a little bit so it's not a direct bolt on.
The 3120 carb is a different bolt pattern and would require a custom intake manifold.
Jusgunn3
11:15 PM
California
I got one for mine but need to figure out the throttle rod, the stock one hits the choke on the needle side of the carb. I am going to buy some rod and see if I can jog it around a bit.
