farminkarman
I like the red & black ones
- 2:40 PM
- Aug 17, 2020
- Neenah Wisconsin
After building this 2100, there are a few thoughts I will share. First, starting the saw isn't bad at all with .020" from the band and a 98 exhaust roof. Second, if I were doing another one, I think I would still use the 395 piston. I would also raise the exhaust to 96, transfers to 116 sloped to 118, and epoxy the intake to set it at 76-77. Along with raising the intake floor back up with epoxy, I would probably raise the intake roof a bit to get more area and offset the 0.070" the jug was lowered by machine work. I would also look at trying to swap in a 394xp carb.Great build Gregg. TY.
I like the uppers and tunnels.
I’ve got a “crate” of these. I gotta get to them, and your build is a big help.
I wonder if the jugs could be drilled for a decomp.
