- 10:52 PM
- Dec 4, 2015
- In a meeting
So here's the issue guys. This piece of metal is suppose to be welded to the crank like the opposite side.
I have had this happen before a few years ago. Simple solution, Either I replace the crank or I reweld
the weight back on. I'm gonna weld it back on tomorrow. These cranks are getting harder to find in
good usable condition.
Simple solution is to never tap on either end of these 123cc Mac cranks. The SP125's have bolt on weights
where all 797's and 101's are welded weights.
Will be going back together tomorrow.
Hard to plug weld with the other counter weight in the way. I will tig
it back on with a little better weld.
What filler rod are you going to use ?
Do you preheat the crank ?
