1988 Ford F-150 Resto Thread!
Steve
Excellence!
3:37 PM
Got cabin fever and braved the snow to try out the spotweld cutter. This thing is amazing. Lightyears ahead of the old cheap ones ive had in the past. If i had this tool 14 years ago i would never dreaded aligments on the Ford Taurus.
Steve
Excellence!
3:37 PM
Once i got the firewall reinforcement off the old cab i decided to not waste any time cutting out that firewall. It had many cracks in critical spots that made me decide to just modify the new cabs firewall. Ill use the reinforcement as a template to cut and drill new holes for the steering column and clutch m/c. Ill then just weld a 1/8" plate over the old harness holes and cut a round hole for the 88 body harness.
Steve
Excellence!
3:37 PM
Took the rear cover off the rear diff to check the posi spring and found milky fluid and pitted gears:(
Steve
Excellence!
3:37 PM
I pulled the cover on the parts truck diff to see what gears were in there and a nice set of 3.55's!
Im going to Frankenstein a rear end. Use the carrier, axles, and pinion flange from my assembly and the gear set and housing from the parts truck.
stihl_head1982
Here long time
4:37 PM
USA
View attachment 166088 View attachment 166093
Looks like there is no dust gathering on this project. (a derail question concerning a strut brand for my 2006 Dodge 1500 -- anyone got a recommendation? Gonna buy the parts online.)
Carry on. Can't wait to see the frame parts when they come back from the blaster -- all ready for the reassembly.
4:37 PM
I gotta replace the struts on my 05 f150 too. One side the spring broke at the bottom. Was gonna get the fcs brand with two struts and back shocks for 150 bucks from rock auto.
Steve
Excellence!
3:37 PM
Monroe quick strut. Get the lower strut bushings and bolts too. They are usually froze in the bushing.
Steve
Excellence!
3:37 PM
Stick with a good brand. Cheap springs/struts usually cause poor ride quality and noise.
Bigmac
1:37 PM
Oregon
Can you show a pic of the new spot weld cutter? Curious if it’s the same style I used on the camaro!
