Picking up my new Dodge Ram today
Sloughfoot
1:01 PM
Norcal
3.6L V6 Pentastar. Very early on in my research I ruled out a V8 and no turbos for me.
I hear you. The model truck I'll get next has recently replaced a 5.7 V8 with a 3.5 V6 that has 50 more h.p. than the V8 had.
I've had a supercharger but not a turbo. Liked the supercharger because you could putt around and get great m.p.gs or haul ass and not.
lehman live edge slab
Live Action
3:01 PM
Mn
If it’s the truck I’m thinking it is may still want to hold off awhile because they are still having lower end issues. While not huge numbers it’s a lot more that’s the 5.7 ever had and the rear axils aren’t doing so hot either at the moment.
Milage isn’t much if any better on the 3.4 either. I have lots of buddies with modified trucks and cars most of them prefer the turbos because you don’t have a constant parasitic loss driving the compressor if just putting around not needing boost. They said they’ll take the slight turbo lag over the constant hp loss plus no belts ect to deal with but both do the job.
Sloughfoot
1:01 PM
Norcal
My dad pulls his heavy fiberglass boat with the 3.6 Grand Cherokee and has had no problems in 214,000 miles. It has my respect!
How one is geared can definitely make up for less engine. We put 4.56 gears in our little Toyota. Now with the cruise control on it stays in drive pulling a trailer on hills it used to shift down to 3rd on.
EFSM
3:01 PM
Extreme southern IL
Yeah they just recalled another batch because machining debris was left in the crankcase. I hope someone has a warm sitter.
EFSM
3:01 PM
Extreme southern IL
Live Action
3:01 PM
Mn
Yep. Building engines in Alabama may not have been the best decision. Kinda like that little shortcut the Donner party took.
Not 100% sure just the USA built engines some Lexus had issues also with Japanese engines. The machining debris may have been an excuse it sounds like and many are starting to believe it’s the web structure that clamps the mains not being designed correctly and the oil ports not providing enough oil to main bearings. Since it’s now been 4-5 years they should have a handle on flushing the block out.
FergusonTO35
4:01 PM
Boonesborough, KY
All I can say is, extended oil drain intervals are a bad idea even when using premium synthetic oil and filters. All the contaminants build up and need to go somewhere, and the best oil and filters in the world have their limitations as to how much they can hold in suspension before damage starts. In addition to the unrealistically long drain intervals, remember that most people are already exceeding that by quite a bit, sit in their cars idling for many hours, and never check their oil level.
Live Action
3:01 PM
Mn
I go every 4000 with synthetic oil and the good 10$ filters in my 2.7 ecoboost same as I did in my 2014 3.5 ecoboost. The gen one 3.5 was known for timing chain stretch and phaser issues but mine had original timing set at 115,000 when traded in. Would have kept but dealer offered great trade on new one.
SawAddictedFarmer
3:01 PM
Um 115k ain't much.
Live Action
3:01 PM
Mn
Um 115k ain't much.
Never said it was and would have kept it but got great trade because they needed used trucks to sell. My 2.7 has 71,000 right now and I plan on keeping my cousin has a 2016 2.7 and it has 285,000 on it original turbos and everything. And all trucks can start to require some maintenance at the 100-125,000 area. My best friend is a Toyota guy and he had to put a new timing belt and radiator in his tundra 4.7 at 120,000. Yes it’s scheduled maintenance for belt but the radiator that was shot wasn’t and that was like 3000$ repair between belt and radiator. So still putting 3000$ in at 100-125000 to keep going they all require money and maintenance. All the cars from when I was a kid had odometers that rolled over at 99,000 and there was a good reason they did because it was worn out at 100,000 lots of times body or engine sometimes both. Also with the 3.5 in the 2014 lots of people did timing sets at 40-60000 miles if they did 10-12,000 mile oil changes. People that did 4000 like me got 125-200,000 even on the small single chain that ran both banks and was prone to wear and stretch. The 3.5 gen 2 went to double heavier chains and they added port injection to go with direct to wash the intake valves preventing carbon build up problems like the gen 1 2.7 and 3.5 had.
OnlyStihl
2:01 PM
PNW
Not in suspension, but in the oil filter. Replace the filter, then tear into it and get an idea how the motor is wearing. There's much much more that goes wrong on an auto before the engine dies.
OnlyStihl
2:01 PM
PNW
Major upgrade today. First off though I've put about 800 miles on the truck and it hasn't detonated, yet. I am very wary, but so far it drives like a dream. Yesterday it took me about 10 minutes to figure out how to open the tailgate. I thought Good Grief, so it begins. Well, it has an electronic lock. A lock, on a pickup. The bed is wide open for theft. No need to lock a tailgate, and I did not lock it, it locks itself. Yeeeesh....
Today I drove to Spokane and bought a set of wheels and tires I found on Craigslist. Motivation was to get some All Terrain tires. To reshoe with a new set of tires would out spend what I did on this set. Upgrade from 18" wheels to 20" wheels, steel wheels to aluminum alloy, and A/T tires with 80 to 90% of the thread still useful. Good Deal! The original all-season tires will be on the truck April/May thru Oct, the A/T tires during winter like conditions.
Woodtroll
4:01 PM
Mtns of SW VA
Glad it's doing well for you! At one time tailgate theft on newer trucks was a big deal, because they were so quick and easy to get loose, and so expensive. I don't know if that's still as common or not, with the wiring harnesses and such attached now, but that was part of the reason the tailgates were designed to lock themselves. It does seem silly with an open bed, except for that.
FergusonTO35
4:01 PM
Boonesborough, KY
For most of my life, whenever you saw a pickup truck actually being used professionally it was a Ford Super Duty about 90% of the time. Nowadays, I'm seeing Mopar claim that turf more and more. I wonder if its because Mopar has been stuck in a situation of having to constantly make sweetheart deals on trucks just to keep the doors open for the past few years? Thats all anybody buys from them around here.
Live Action
3:01 PM
Mn
We bought a bunch of rams at the mine I work at but the hemi can’t handle the idle time they get and there’s been many replacement engines and a fair bit of electrical issues. They are down to the last few rams and have gone back to ford and Chevy only again. They quit fords for a bit after they went to aluminum i suppose as kind of a protest being I work at a taconite mine in mn but now are buying them again. The last of the rams here sound like they have someone trapped under the hood with a small ball peen hammer rapping on the fenders. All of them need the cam and lifters replaced so they will be the last of the rams.
OnlyStihl
2:01 PM
PNW
Yup, from my research all V8s are problematic and to be avoided. The cylinder deactivation has been a disaster. When I first learned of it, I thought that was a bad bad idea. Just having active pistons dragging dead pistons thru the motions seemed counterproductive.
The other day when picking up the new wheels and tires, I had to travel over some mountains and took the opportunity to slam the pedal into the floor. Impressive. The 305hp even with this very heavy truck felt very strong and responsive. Smoothly shifted down several gears and raced forward with little effort.
