- 4:31 PM
- Feb 5, 2016
- grafton wv
3" pocker all ya got?
So a long reach indicator in the squishy band sounds like the reason I have kidsYa see that @Stump Shot ?
Long reach indicator to get right up by the squishy band. Then back and forth till there is no run out at the top, or the bottom.
Move the 4 jaw to get the top end right, then tweak the bolts to move the bottom. Then back to the top.....etc....etc....etc....
Can ya get in there deep enough?
You know, to that sweet spot
I'm gonna stop for tonight. Still gotta cut all these bases. I got the jugs fitted up to the hybrids, and got all the clearances checked to know how much is coming off the bases.
Just for chits and giggles I checked the same jugs on a 460, then on a 440. There is a .005" deck height difference.
So Randy with this many on the bench at the same time are they all for customers or are you building some for yourself to sell?
Like too much taller? And thank was just think which can get dangerous!the crown on a 064 is taller than the 046 piston
See what I did there? Do ya? lol
You gonna need a Ditch Witch
I rike me some 1128.
Day be muh favrite
Quad vs 2 port?OK, I'm gonna play a Trump Card, kinda TM style.
What do you think makes the biggest difference in performance between a 461 and a 460???
Drill the main on the 461 will do the same Im bettingI've heard some say they are a gain and others said they seen no difference
Nice saw and bar.I'm Pretty fond of the newer ones:
