084 vs 088. Which is better?
6:53 AM
96.5 isn't bad. 97 is stock oem. Still 120cc saw with plenty of torque.
Brewz
8:53 PM
Hunter Valley - Australia
Yeah I guess.
Would have been happier if it was closer to 100*
Will see what its like when it shows up
Brewz
8:53 PM
Dropped all the parts in the parts cleaner and they were boiling away after a couple minutes
VinceGU05
one day when i grow up...
6:53 AM
S.E Australia
It needs a birthday
The aux oiler cable is still good so I now need to work out how to get the tank handle off without breaking it.
Time to consult the ipl
I think I will start another thread on it's rebuild
flip the plunger for extra oiling ( next to the start stop lever) over. it pulls on a cable with a ball end. then its like any normal saw to separate.
VinceGU05
6:53 AM
S.E Australia
That's pretty well the limiter on them. That's why they're such dogs now. A coil swap to a 441 or 361 coil if I remember right fixes that. They should be limited at 13k and you wouldn't need to mess with them. Same with the 9.6k limited 3120s. They cut at the limiter the whole time.
Ok.so this is how a 660 coil sits in there.
Turned these up at work.
Made a bridge out of some flat. And screwed it down.
Because the difference in the flywheel diameter, it needs to be tickled a tad on the ends. I just used a parallel burr.
Brewz
8:53 PM
nice work mate
I am going to run mine on Sunday with the 1308 coil but will be doing something similar to see how it runs.
Iron.and.bark
6:53 PM
Thanks Vince,
Wish I had taken photo's when I did it. Made a bracket like this myself.
-------l'''''''''''
Brewz
8:53 PM
I picked up a very low cost 084 today as a build project.
Its had a hard life, but I am not worried about looks on this one. I want to fix it up to be an ugly duckling milling saw.
I want to replace the clutch drum and oil pump worm gear with 088 units but have been told they wont fit properly?
Is this true or will they just bolt in?
Just want to find out before I spend the money
Brewz
8:53 PM
No mate they are very different parts.
The 088/880 has a system for the worm gear similar to whats used on 044/066
The older 084 has a different worm gear that requires a sprocket with 4 slots in it.
