076-no spark.
skip sail
11:26 AM
Victoria Australia
I've got a low hour early 076,massive comp,but no spark.
Was told its probably either the coil or the ignition module,both unobtainable.
Is there an alternative option (i.e the Nova 11 ignition module etc) or a way of getting spark to what would be an excellent saw otherwise?
Dont know much about these,but can take some pics if that helps ID the model better. Its not the super,the badge reads 076 AV electronic (no quickstop)
thanks
Lee H
6:26 PM
cape cod ma.
I just did a coil replacement on a 075 electronic. Got it off ebay
an aftermarket one and it runs sweet now.
Chainsaw Jim
Con Artist LLC
6:26 PM
Springfield Oregon
I've also had luck with the aftermarket version. There's a few high priced Chinese versions and the saegenspezi is about 60 bucks.
9:26 PM
I would say if the coil is good about any solid state trigger device should work that would fit some place .I could tell you how to test a coil but it's just as easy to Google or you tube it .
