066 with 385xp piston
Chainsaw Jim
Con Artist LLC
10:47 AM
Springfield Oregon
Jim, with the lower transfers opened up like that are you planning any mods to the cases.
Just wondering if the transfer inlets may be blocked off a bit once the cylinder is back on the saw.
The spacer should give it the room it needs. I'll match the shape accordingly.
Stihlbro
1:47 PM
Virginia
Looks like you can make it all work. Fitting the intake boot and getting the muffler mounted with a 3 mm spacer may change a few things. The way the piston is cut and cylinder cut to feed transfer is workable. Port timing wise, I see options that are not allowed with stock piston. Great thread, I’m excited to see the end results.
Moparmyway
Its just a saw
1:47 PM
In a meeting
