066 HD filter conversion
Crocodile Lyle
OPE Member
4:24 PM
Salina, KS
I'm working on an older model 066 with the shallow air box cover, it has the two thin/domed filters. So I'm wanting to convert it over to the HD style filter and was hoping someone could provide me with what parts i need and or the part# needed to do such. I'm not interested in the aftermarket max flow setup though. Thank you
jmssaws
Banneded
4:24 PM
You sure it's a 066?
I believe you have a 064.
Pics?
Definitive Dave
Piss Rev Mafia Member
5:24 PM
Central Ohio
On an 064 or early 066 you need a new filter base and air filter cover as well as the filter. Both of those pieces are NLA from Stihl for a long time and bring good money on Ebay, I snatch up every one I see.
On a later 066 you can swap over to the standard 660 parts that are plentiful and cheap. I haven't studied the changeover, so maybe all of the late model 066s already have the HD filter setup.
Dave
Crocodile Lyle
OPE Member
4:24 PM
Salina, KS
Would you happen to know the part numbers for the base and cover on the nla 066 hd filter setup? I'll just keep a close eye on ebay for them
Gunn
Yay sawz
4:24 PM
Plover wi
Right, if you did there'd be a small snorkel that interfaces with the filter base plate.
Gunn
Yay sawz
4:24 PM
Plover wi
You'd want the one without the port for the intellicarb. I've been meaning to get you the pn, I'll get you a PN in a couple of minutes.
Gunn
Yay sawz
4:24 PM
Plover wi
image.jpeg image.jpeg 1122 124 3460.
The one you posted would work, you'd just want to plug the hole for the intellicarb.
