066 Check.
066 redeye
9:41 AM
Tasmania,Australia.
Yes, this is a transition saw and it is legit. For a short time, there was a flat-top, small oil tank, poly-flywheel saw. It's a strange animal. I bought one
myself new for my logging business I had at the time.
Are there any numbers on the ignition?
Ron660
4:41 PM
NW Louisiana
What year did they stop making the red light 066’s? Guess my model, flat-top no-decomp, was next.
Also, just guessing the 066 phased out the 064??
DND 9000
11:41 PM
Germany
End of 1994. (TI 51.1994)
The existing CDIC ignition module with speed limiter (1122 400 1307) used with the red LED was replaced by the EY-V ignition module without speed limiter (1122 400 1311).
MG porting
2:41 PM
Wa
My redeye 066 looks like you richen it up until the light comes on then lean it down by 1/2 a turn on the H screw
View attachment 234788 View attachment 234789[/QUOT ok this is how you need to start make sure that the H side is out from bottom one full turn then rev saw if the light doesn't come on turn the H side in until it does then when the light comes on then you turn the H side out one 1/4 out that will put you in the safe zone my vary a little because of elivashun but still the same process.
