066 redeye
- 12:59 PM
- Jun 18, 2017
- Tasmania,Australia.
Hi gents.
Looking at rebuilding an 066.
This unit is a small (oil) tank 066,but has a poly crank with the larger fw side seal.
I thought all small tanks had the small ally crank with the small seal.
I know you can't fit a poly crank in an ally saw as the poly crank is wider by about 5mm.
All the 066/660s I have worked on have been either small tank ally crank or large tank poly crank.
So is this just a production change over saw?
It also has a 3 leg (046?) style coil.
If the cylinder I got in a box of parts is from the above saw it is decomp.
Cheers Chris.
Cheers Chris.
