064/056 mag11 build
RI Chevy
11:54 PM
earth
So you are using a Mahle setup?
RI Chevy
11:54 PM
earth
Sounds like you can get a little more out of that.
jmssaws
Banneded
10:54 PM
Gotta do some carb work.
It can't feed it enough to go.
It's probably still faster than the other saws here. I can pry it through the wood.
It sounds a good 1000 rpm slow to me,maybe 2000
I'll fix it tomorrow
jmssaws
Banneded
10:54 PM
So.... What rpm did you get out of it?
I didn't check.
It's probably around 13?
To make it run up high it has to be so lean that it won't idle,if you tune it to idle then it's to fat to run up high.
I'm told adjusting the pop off pressure can fix that problem.
Deets066
AKA Deetsey
11:54 PM
I didn't check.
I think you could drill the jets a little and fix the problem also
11:54 PM
Any chance you are having the same muffler issue you did with that 066?
That's a relatively smaller case for the larger jug. At 119, you may be pushing charge out the muffler again.
Do you think a little more intake would hurt it Jason?
Brush Ape
Direct Connection
10:54 PM
Metropolis, Il
