044 build
2:04 PM
Take a Pic and try to measure where your seals are now. You’ll need to put them back at the same depth. Don’t forget.
BuckthornBonnie
2:04 PM
Penn Yan, NY
The puller is the best way, but I’ve used a good vice, heat, and a punch before with success. Foil or other shielding around the crank lets you heat the bearing with a torch or heat gun. Then, you can carefully pry up the bearing with screwdrivers. Mweba may still have a video with a version of this procedure. It was on YouTube a few years ago (290 rebuild I think).
This is if that bearing will get replaced... don’t plan on using one removed by this method.
Basher
3:04 PM
Canada
The proper tool is a bearing separator like the one pictured below, it is already connected to pull the bearing off the crankshaft so its a bit difficult to see how the pulling plate grabs behind the bearing shell but its basically two halves of a plate,
Adirondackstihl
2:04 PM
Upstate NY
That’s a nice set!!
Where’d ya pick that up?
