NZsawyer
- 5:27 PM
- Aug 11, 2017
- New Zealand
Cheers guys I might try the mallet method. That is if I can get this stupid cylinder bolt out, rounded the bugger completely. Any ideas how to get it out? I've tried tapping in a larger size torx and even a hex but it just keeps getting worse. Driving me nuts!
I just bought a bunch of SFK 6202 C3 bearings on eBay for $5.70 each shipped. They have the rubber seals in them that pull right out with a dental pic.slacker 6202’s C3 clearance are what Stihl used in a few OEM 044’s I have had apart. For what it’s worth [emoji3]
Yep. Mastermech also had a failure with those yellow, waxy gaskets that came in 460 AM gasket kits; they’re junk.I'm running aftermarket seals in my 046, that I rebuilt four years ago and they're doing fine. As long as a guy is running good quality oil mixed correctly, the aftermarket seals do fine and give a good service life.
As Randy has pointed out in other threads- those yellowish, thick aftermarket case gaskets are crap. The thin black paper ones are ok. Even an OEM case gasket now I still fortify with Yamabond.
This is because a lot of modern saws have a long, thin run in the case under the muffler and many larger saws have failures in the gasket there (particularly 084s, 385s, and 064s).
As Al mentioned, any decent brand of 6202 bearing with the right clearance is fine on the flywheel side.
The white paint they market is absolute garbage.I went ahead and ordered all oem parts to be on the safe side, forgot to ask if they sell the white paint that goes on the crankcases though. Thinking I might do a few touch ups while it's apart
Bugger what would you recommend? Might just have to have around for something that matchesThe white paint they market is absolute garbage.
Don’t waste your $
Too “white” IMOI used GM arctic white paint in a spray can.![]()
OEM Flywheel puller
$8
