038 muffler
merc_man
merc_man
6:54 AM
southern ontario
I was thinking about doing a muff mod on the o38. I noticed its got a duel factory exhaust. Is it worth doing anything to it?
The main reason was i hate how the exhaust always blows on the case/clutch cover and discolors it. Mabe i just try to keep my saws too clean.
merc_man
merc_man
6:54 AM
southern ontario
Mabe i should open the baffle looking thing too?
jb-chainsaws
11:54 AM
UK
That muffler is off an 038 magnum, I say run her like she is!! She won't gain all that much without hurting your ears from more exhaust work in my humble opinion
6:54 AM
Those are good you can make them louder but it wont gain much if any they did those right from the factory.
merc_man
merc_man
6:54 AM
southern ontario
It is a magnum. It has hardly any hours on it. It is a good strong saw as is. Just didnt know if it would ga8n a little fr9m a mod till i noticed it was factory dual.
merc_man
merc_man
6:54 AM
southern ontario
Put a vent on the other side. If you're lugging the 038 torque monster around, you might as well let it breathe. The baffle serves little purpose. Gut it!
Re tune appropriately. ..
Should i take the screens out of it. I normally do.
And you think just cut that baffle thing out?
6:54 AM
They aren't that loud with a completely gutted muffler ,no baffles ,diverters ,nothing but the shell ..Second port cut it even .---wear ear plugs----
Glock37
6:54 AM
Monroeville Pa
On my mag that randy did with the 2 port with gutted baffle will drive you away with a hi pitched roar Just find a oem 3 port and its a little softer but runs the same
merc_man
merc_man
6:54 AM
southern ontario
Have at it. Give the dog a treat for guarding the saw. Nice rebuild!
Not a rebuild. Its all original other then i cracked the chain brake handle few years ago and baught new pem one.
It was a relatives saw he got thrpugh insurance and never used it. I borowed it a couple times when it was newer. I finally asked him bumch of uears ago if i could by it. I got it for 400 bucks. Here new it was 1200.
WooHoo223
Semi Professional Lurker
6:54 AM
Along the Mohawk
This is from a 038 AV that I recently acquired. The back half of the muffler does not look original. It also has 2 exhaust ports on the clutch side. Not sure if the deflector is OEM but the muffler case does seem to be. I opened up a few holes in the baffle on the bottom side, like the shape of hole needed to install a pipe at a angle. Saw doesn't seem loud to me and I like to see the smoke go every which way on startup.
