028 intake port.
Mathewsdxt75
Learning OPE member.
5:30 AM
wisconsin
The intake port on this 028 an has this little nipple on the piston side, can this be removed when opening up the intake port?Intake_zpsvuyqg164.jpg
P.M.P.
Stiff Member
6:30 AM
Michigan
I don't know because I just *f-word chit up if it were me I would ask or send it to this guy @tree monkey
Mathewsdxt75
5:30 AM
wisconsin
I did what you thought you would do.... :(
CHIT is an understatement. o_O
Can thin it a little but cannot remove it, holds the ring ends in place.
I guess I will slide the cylinder back on and see how bad I flubbed it up.
Mathewsdxt75
5:30 AM
wisconsin
I put the cylinder back on and see that both ring ends are on either side of the intake opening and supported by the cylinder wall. But I do see how the bottom ring may not have enough support. Since I removed the little nipple, I assume it is a consensus that I screwed this jug?
6:30 AM
Is the whole ring into the intake port at bdc? Maybe a base gasket delete (If possible) would lower the cylinder enough to keep the ring above the intake opening. Or like Brad mentioned, leave the bottom ring out
Adirondackstihl
6:30 AM
Upstate NY
Nah
The gasket would need to 0.1875” thick....lol
Mathewsdxt75
5:30 AM
wisconsin
With the base gasket out, even the top ring just barely starts to peek into the port at bdc. I think the top ring will be fine, but then I thought taking out the support nip was oko_O
just stake the bottom ring center of port, the rest of the ring will still serve a purpose
Damn... that is a very intriguing idea....
