Mathewsdxt75
Learning OPE member.
- 11:15 AM
- Feb 25, 2016
- wisconsin
I did what you thought you would do....I don't know because I just *f-word chit up if it were me I would ask or send it to this guy @tree monkey
I guess I will slide the cylinder back on and see how bad I flubbed it up.Can thin it a little but cannot remove it, holds the ring ends in place.
I screwed this jug?
Hmmmm44mm.
NahIs the whole ring into the intake port at bdc? Maybe a base gasket delete (If possible) would lower the cylinder enough to keep the ring above the intake opening. Or like Brad mentioned, leave the bottom ring out
Oooh. Dat's a bunchNah
The gasket would need to 0.1875” thick....lol
Well.....maybe not quite that much, but it would def need to be thicker than the stock 0.020”Oooh. Dat's a bunch
Damn... that is a very intriguing idea....just stake the bottom ring center of port, the rest of the ring will still serve a purpose
