026 Carb's
Duane(Pa)
It's the chain...
3:54 AM
Centre County
is there any tricks to make a 026 start easier ?
The choke flap is in the dang air filter. It has to close good to get her fired up, then stay out of the suction of incoming air at WOT. Usually takes some messing around to get it right on both ends. The key for WOT is mostly in spring tension.
leadfarmer
Hot Rod !!!
3:54 AM
S Central PA
It's seems like all 026 I have and others I've been around always take a lot of pulls to start when cold
Duane(Pa)
It's the chain...
3:54 AM
Centre County
I guess so.... But who wants to dick with a primer bulb system???
3:54 AM
Like Duane said, really good chance it's the choke not closing. My 034s is like that. Not sure if it's the control lever, the electrical spring, or the air filter. It lacks about an 1/8" from closing completely. If I don't wanna pull it 10 times, I have to hold the throttle down while holding the choke with my right thumb, and drop start it.
leadfarmer
Hot Rod !!!
3:54 AM
S Central PA
I shall try that. Thanks
3:54 AM
I think the primer system nowadays just primes the carb full, and recirculates the fuel back into the tank. It doesn't actually squirt fuel into the cylinder any more
3:54 AM
It's easy to check. Pop the cover off and look from the right hand side. Put the choke full on, and let off. I bet you'll see the control arm back off a bit when you let off
leadfarmer
Hot Rod !!!
3:54 AM
S Central PA
Thanks . I will check it out. If so is the only fix to start like previous stated
Duane(Pa)
It's the chain...
3:54 AM
Centre County
I think the primer system nowadays just primes the carb full, and recirculates the fuel back into the tank. It doesn't actually squirting fuel into the cylinder
I get that....It's still a lot of monkey motion. I am SO old school. The simpler, the better. Anything to avoid extra fuel lines to melt in the corn syrup gas......
3:54 AM
Oh I agree. Me too
Depends on what is causing it. Mine looks fine, but I might be able to bend the spring to get it to fit the choke notch better. Might be a worn out control lever or worn filter lever
3:54 AM
Oh I agree. Me too
Might also be 30 years old lol
Redfin
Meh...
3:54 AM
Central Pa
Rodney, I had to trim the flap on mine to get it to close tightly.
Deets066
AKA Deetsey
3:54 AM
I have to pop the air filter cover off my 034 to start from cold. The choke just won't close all the way with it on. I can't find where it's hitting, I've ground here and there but it just won't quite close with the cover on
Duane(Pa)
It's the chain...
3:54 AM
Centre County
So how many pulls does it take you guys to start it when its cold
I'll count, but I know its 8-10....anything over twelve and I call my wife or Jason. JK My saws sit too long between uses:(
leadfarmer
Hot Rod !!!
3:54 AM
S Central PA
That sounds about right I'm going to go out here and check I'm hand sanding the squish band on a 44 and I'm getting the shats of it.....heheee
3:54 AM
When you push the control lever down to choke, and let off, does the lever come back up a bit? Mine does, and the choke gets a slight gap in it
