- 11:30 PM
- Jan 8, 2016
- Farmington, CT
Ok, who's made this mistake?
So, ran a freshly rebuilt 372 at Dan's this last weekend. Power was...eh....ok. Not great. gave out in the cut, wouldn't idle quite right. maybe airleak, who knows. carb is kitted, coil is oem, but used.
was having issues oiling too... so I may need to take it apart and investigate that.
did a comp reading.... 185. which is about where it started anyway. pulled the muff. starting to bugger the piston .
pressure test. holds pressure fine, but fails on vac. asdfjkl;asefo;ijaweo;fijawo;efijao;weifj
WRONG EFFING CLUTCH. the clutch goes on sloppy and tightens up, but is obviously not the right thread. wtf??? I don't know how did I didn't notice that when I was initially putting it together, but it didn't even occur to me that husky made an identical clutch with different thread.... WTF would they do that???? m15x1.25 vs m14x1.25 372? I spun another clutch on and the leak dissappeared.
I must have gotten a 576 clutch in a pile of parts and not noticed.
now I gotta get ANOTHER new piston and cut another popup. UGH.
KUDOs to CRAIG TIMMONS from my youtube channel for the idea that this is a 576 clutch!
