Ok, so I'm going to respond as a general statement addressing a few different people, just so it is all kept in one post, because clearly some of my responses have gone undetected.
1. I have a working carb on the saw now.
2. I have 2 OEM used carbs on the way.
3. A new genuine carb here in Aus is almost $300.
4. It is a kit saw. I have a Cross top end on it, muffler mod, timing advance and popup piston. It makes around 180psi and goes good.
5. I have many other saws, so I'm not desperate to be back cutting with this. It is a toy.
6. I'm retired. I have plenty of time on my hands. Plenty!
7. I'm interested in what this problem is, not about getting the saw running, because it already is with another carb.
8. The metering lever is set correctly. The carb works perfectly right up to the point it floods at 13 grand.
9. I am using aftermarket parts because it is an aftermarket carb. Furthermore, I don't know whether some of you guys in the states understand just how bad we get f@#$ed over price wise here by Stihl. And to top all that off, my dealer (the only one for 100km) carries no parts stock at all. Well other than filters and chains and such. Everything is a 2 week wait minimum.
10. I have run it with the OEM carb from my MS660. It runs perfectly then.
11. I don't have an "ego" problem and that whole comment was unnecessary.
12. Clearly some of you guys fix saws for a living. This causes you (correctly) to look at things from a perspective of time is money. That is not my perspective. To me, time is........time. It gives me something to do for a day or so when I encounter a problem. I almost look forward to them in a way. A challenge. Yes I used the word frustrating to describe this problem, but it has a different meaning for me than maybe you, because for me time does not equal money.
13. After reading
@Basher 's post regarding the nozzle check valve I reinstalled the dodgy carb and recreated the problem. As the saw hits around 13000 fuel just pours out the nozzle. So much so that it then drips (large droplets) after the throttle is closed and subsequently causes the saw to flood and die if I don't feather the throttle. It appears to me he is onto it. So I will look here first, then if that doesn't change anything, move on to the next area. I don't mind how long it takes, I'm learning about how the different components effect things.
I hope this addresses some of the concerns raised.
