The AM carbs really are a cluster fck lately. I just got through diagnosing a carb that would flood the engine within two pulls of the recoil so its not doing like the OP`s saw is but I had the owner mail me the carb, I tried online to diagnose and have him fix it but couldn`t figure it out til in my hands. I did a methodical teardown looking at each part very closely. This is what I found on this particular carb, the little nub on the metering diaphragm that presses on the metering lever was .010 longer than an OEM one, the metering lever offset was way off, couldn`t bend it far enough to make it work, tossed both aside. Opened up the pump side and found the pump diaphragm was totally incorrect for the carb, it left the impulse port and bowl completely open to incoming fuel, the fuel just ran straight down the impulse line into the crankcase. After installing a completely new OEM kit with proper adjustments I first tried a pressure test and the carb failed, there was an air leak in two places between the pump side cover and the gasket. No matter how tight I turned the holdown screw it still leaked. I could have just swapped the cover for a spare OEM one but instead flattened out the leaker using a couple of machinist files, voids could clearly be seen after just a couple strokes of a flat single cut file, several more strokes brought the cover flat/true enough for it to seal easily with just the gasket. Installed the carb on one of my test bed saws and it then ran just fine, will tune and hold a tune, reinstalled it on one of my work saws and it ran 4 tanks of fuel through it without further adjustment or problems. Long story but it just goes to show how bad some of this AM stuff is getting. Couple years back the AM carbs seemed to be way better and far less problematic.
