My bad. I call all tube type fuel feeds "straws."
They/these carbs have a check valve in the high speed tube bringing your fuel up to the venturi. The blow-off valve might be messed up. When they give problems most times it is missed. They normal just seat shut or get clogged with black death. Oh boy. Black death: The junk in the bottom of an old outboard boat motor fuel tank. Think, tar like muck.
Tap it out and test it. Might just be stuck with machining dust. You can always hope.
Next place to look is in the carb body. People make mistakes in drilling port holes and fuel feed ports. maybe they left out a key air bleed or forgot a welch plug. The only way to fix it is replace or learn the entire carb and fix it. Been there, done that.
Remove carb
. Replace with second carb.
repeat
study the carb
test
This ^ IS the "Correct" procedure to fix a street raced Holly carb.
Chainsaws are much eaisierer. Smash it. Call DD at CCC, done.
Your Welcome
